Hi all!
For example, I set disable parity generation and checking at UART0 Line Control Register. Then I could write "S0IN = 0xAB" to simulate uart input, and it's ok.
But I neen to use UART with parity (even). How could I correct init S0IN? I tried "S0IN = 0xAB" and "S0IN = 0x1AB", anyway Keil say parity error.
You haven't said what chip you're using but, almost certainly, the SIN register comes after parity has been stripped - in just the same way that it does not contain the start & stop bits!
You usually don't get to see the parity bit itself - just a status bit that tells you whether there was an error.
You will have to study the documentation for the specific processor for details...
I use LPC2129. When I set no parity, then everything is ok, I have the same result at Debugger and at real hardware. But when I set parity_even, my programm at real harware work fine, but at Debugger always set parity error (PE).
So, I found some words at: www.keil.com/.../uv4_sm_uartcommunication.htm
"You may write 8-bit or 9-bit values to SxIN. [...] Other special values may be used to simulate parity or frame errors."
So, could you please tell me how to correct use virtual register S0IN to simulate parity input.
I could use "real_device <---> com_port_terminal" and "keil_debugger <---> serial_window". For example I type one symbol at keyboard.
If I use uart with no_parity, both variants work equal.
If I use uart with even_parity, "real_device <---> com_port_terminal" work correct (the same as befor with no_parity). But "keil_debugger <---> serial_window" generate Parity Error (PE) after any symbol typing.
So, how could I adjust Keil Serial Window to correct send symbol with parity? Or how I could use S0IN to correct send symbol with parity?
Starting to sound like an issue where you should involve Keil support.
Please open a support issue, and then post back in this thread with the answer you receive from Keil.
