real view comiler help for cortex m3
we are using ti cortex m3 uc. keil uv 4.03
i want to implement a bootloader so that the bootloader will the apllication ie my main function.
but i was wrote the code for resetisr handler (i am usign rvmdk).
i get error like :
call.c(150): error: #1113: Inline assembler not permitted when generating Thumb code
// #include"uart0.h"
// Forward declaration of the default fault handlers.
void ResetISR(void);
static void NmiSR(void);
static void FaultISR(void);
static void IntDefaultHandler(void);
// The entry point for the application.
(is it right)
#if defined ( __CC_ARM   )
  #define __ASM __asm                                         /*!< asm keyword for ARM Compiler          */
  #define __INLINE__inline                                   /*!< inline keyword for ARM Compiler             */
// External declaration for the interrupt handler used by the application.
__irq void UART0_ISR(void);
//extern int main(void);
#ifndef STACK_SIZE
#define STACK_SIZE                              64
#endif
static unsigned long pulStack[STACK_SIZE];
extern unsigned long _vStackTop;
extern unsigned long _etext;
extern unsigned long _data;
extern unsigned long _edata;
extern unsigned long _bss;
extern unsigned long _ebss;
__attribute__ ((section(".isr_vector")))
void (* const g_pfnVectors[])(void) =
    (void (*)(void))((unsigned long)&_vStackTop),
                                            // The initial stack pointer
    ResetISR,                               // The reset handler
    NmiSR,                                  // The NMI handler
    FaultISR,                               // The hard fault handler
    IntDefaultHandler,                      // The MPU fault handler
    IntDefaultHandler,                      // The bus fault handler
    IntDefaultHandler,                      // The usage fault handler
    0,                                      // Reserved
    0,                                      // Reserved
    0,                                      // Reserved
    0,                                      // Reserved
    IntDefaultHandler,                      // SVCall handler
    IntDefaultHandler,                      // Debug monitor handler
    0,                                      // Reserved
    IntDefaultHandler,                      // The PendSV handler
    IntDefaultHandler,                      // The SysTick handler
    IntDefaultHandler,                      // GPIO Port A
    IntDefaultHandler,                      // GPIO Port B
    IntDefaultHandler,                      // GPIO Port C
    IntDefaultHandler,                      // GPIO Port D
    IntDefaultHandler,                      // GPIO Port E
    IntDefaultHandler,                      // UART0 Rx and Tx
    IntDefaultHandler,                      // UART1 Rx and Tx
    IntDefaultHandler,                      // SSI0 Rx and Tx
    IntDefaultHandler,                      // I2C0 Master and Slave
    IntDefaultHandler,                      // PWM Fault
    IntDefaultHandler,                      // PWM Generator 0
    IntDefaultHandler,                      // PWM Generator 1
    IntDefaultHandler,                      // PWM Generator 2
    IntDefaultHandler,                      // Quadrature Encoder 0
    IntDefaultHandler,                      // ADC Sequence 0
    IntDefaultHandler,                      // ADC Sequence 1
    IntDefaultHandler,                      // ADC Sequence 2
    IntDefaultHandler,                      // ADC Sequence 3
    IntDefaultHandler,                      // Watchdog timer
    IntDefaultHandler,                      // Timer 0 subtimer A
    IntDefaultHandler,                      // Timer 0 subtimer B
    IntDefaultHandler,                      // Timer 1 subtimer A
    IntDefaultHandler,                      // Timer 1 subtimer B
    IntDefaultHandler,                      // Timer 2 subtimer A
    IntDefaultHandler,                      // Timer 2 subtimer B
    IntDefaultHandler,                      // Analog Comparator 0
    IntDefaultHandler,                      // Analog Comparator 1
    IntDefaultHandler,                      // Analog Comparator 2
    IntDefaultHandler,                      // System Control (PLL, OSC, BO)
    IntDefaultHandler                       // FLASH Control
void ResetISR(void)
    unsigned long *pulSrc, *pulDest;
    // Copy the data segment initializers from flash to SRAM.
    pulSrc = &_etext;
    for(pulDest = &_data; pulDest < &_edata; )
        *pulDest++ = *pulSrc++;
    // Zero fill the bss segment.
      __asm("    ldr     r0, =_bss\n"     <===(here i get err)
          "    ldr     r1, =_ebss\n"
          "    mov     r2, #0\n"
         "    .thumb_func\n"
          "zero_loop:\n"
          "        cmp     r0, r1\n"
          "        it      lt\n"
          "        strlt   r2, [r0], #4\n"
          "        blt     zero_loop");
    // Call the application's entry point.
   main();
    // Enter an infinite loop.
    while(1)
    while(1)
    // Go into an infinite loop.
    while(1)
exactly which segments ie bss, data segments are used in real view compiler.
what i done is is rt?
0
