Hi Team,
We had created the project in Keil uVison 4( Keil evaluation version) and the selected device is LM3S9B90. The test code had been written and compiled the code. In the simulation mode, we are not able to access/ see peripherals of the controller (I2C, SSI, UART etc) in the peripherals tab. But we could see only "core peripherals" option in the tab.
While execution the code, it is saying
" *** error 65: access violation at 0x400FE108 : no 'read' permission *** error 65: access violation at 0x400FE108 : no 'write' permission "
Please let us know the possible issues.
Thanking You.
With Best Regards, Amit Mane
This chip is not simulated so you can select a chip like LM3S8962 that is similar, but as things are not identical this will probably be a cumbersome solution.
