Problem with Keil RTX Overflow checking
Deal all,
I have a problem with stack overflow checking on Cortex-M3 (LPC1768 from NXP) using RL-ARM as below
main stack size: 0x00000200 (configured in startup_LPC17xx.s)
heap size: 0x00001000 (configured in startup_LPC17xx.s, as I used RL-Flash)
individual task stacks:
  InitTask: default
  task 1: U64 Stack1[200/8]     Use UART2, I2C0
  task 2: U64 Stack2[800/8]     Use UART2, RTC
  task 3: U64 Stack3[800/8]     Use FlashFS for SD Memory Card
  task 4: default               Just turn on LED used os_itv_set / os_itv_wait for running checking
  task 5: default               Just turn off LED  used os_itv_set / os_itv_wait for running checking
In RTX_Conf_CM.c, I have the following settings:
Number of concurrent running tasks: 7
Number of tasks with user-provided stack: 0
Task stack size [bytes]: default (50 bytes)
Check for stack overflow: checked
Run in privileged mode: no checked
SysTick Timer: 1000 (1ms) on OS clock 100MHz
Enable Round-Robin: checked
Round-Robim TimeOut: 5
Number of user timers: 0
Task 1 and Task 2 have Inter-Task Communication using MailBox.
If:
- Disable task 3 (FlashFS with SD Memory Card) / Run tasks 1, 2, 4, 5: system run normally.
- Disable task 1 / Run tasks 2, 3, 4, 5: system run normally.
- Run all tasks or (task 1 with task 3): system frozen when task 3 run, Debug on Keil, I found it go to task os_idle_demon.
=> Increased stack size for task 1, 2, 3 to [2000/8] could not solve the problem.
- If disable stack oveflow checking, system run normally.
Based on these factor, I think the problem come from stack overflow checking. What can I do to fix this problem? Any thoughts would be greatly appreciated.
Thanks,
Minh Nhat
