Hello together,
at the moment I am porting some code for LPC2468 from GCC to Realview. I got stuck, when I recognized that changing the FIODIR or FIOSET/CLR/FIOwhatever-registers does NOT effect the state of the selected pins. They stay at about 2.5V, which means, they are still configured as inputs. Off course I set them to be outputs by writing '00' to the related PINSEL- and '1' to the FIODIR-register Same code worked pretty well on GCC, reprogramming the Target with GCC-compiled code works also well, so there should be no problem with the hardware. According to the debug-mode the contents of the GPIO-registers are as expected, but the actual state of the pin stays the same.
By now I couldn't figure it out, so I hope, you might get me a hint.
Regards, Frank
Wild guess: you need to set the "legacy" bit in SCS? Thus,
SCS |= 1 ;
Great one!
That's it. On changing to Realview I also replaced the startup.s. The new one from Keil didn't initially set SCS to 0x21 but 0x20. As I've only tried GPIO-ports 0 and 1, I missed the fact, that it's only those two, that didn't work.
Thank you very much!
