I would like to know whether it is possible to convert IAR library to Keil library, if so, which tool I need to get for conversion.
Thanks Pankaj
I imagine that IAR's legal team would take a dim view of any such tool, if it did exist!
What library, specifically, are you talking about?
If it's a 3rd-party library, can you get the source? Then you'd have to port it to Keil...
Hi Andy,
Thanks for the inputs. We have third party library in IAR format wanted to check if it was possible to convert it to Keil format, as we are using Keil compiler.
If the library license allows you to use with another compiler, then you should normally already have received the source code, or should be able to receive the source code on request.
If you can't get the sources, then that also implies that the license conditions doesn't allow you to port the library.
By the way - most compilers have their own rules for how to send parameters, align members in structures etc. This is called the ABI, and is a common reason for a library or object file from one compiler to not be usable with a different compiler, even if the two files have identical file formats.
You may have multiple PC compilers that can produce object files that may be linked with the same linker, but that will not result in a working binary.
