Hello everybody, Are there any Timing Diagramms of the FILE-Functions in KEIL (Example: fflush, fopen...)? How fast are these Functions?
Thanks a lot!
Wouldn't that be too dependent on the underlying medium?
Execution time depends on the medium being address - RAM drive, SD card, NOR flash, file system complexity etc. How about measuring?
Hi, It would, your're right. It depend also by frequency, so I need to give more information. But I just need the Diagramm for comparing with my Functions.
I need the LPC2148 ARM7TDMI-S, 15MHz Clock on the SD-Card.
Again - is there anything that stops you from actually measuring it? do you have a scope? surely you can use a hardware timer for that, too!
I am measuring, but I'd like to compare with a Diagramm. It would be very nice if I could make some adaptions etc. I'm just trying out...
PS: I'm measuring with a digital oszilloscope.
Here is your answer:
www.keil.com/.../rlarm_fs_technical_data.htm
