i get the linker error while programming for lpc 1114 in lpc11xx.s the startup file as follows.
linking... .\startup_LPC11xx.s(31): error: L6226E: Missing base address for region Stack_Size. .\startup_LPC11xx.s(31): error: L6292E: Ignoring unknown attribute 'EQU' specified for region Stack_Size. .\startup_LPC11xx.s(33): error: L6228E: Expected '{', found 'A...'. .\startup_LPC11xx.s: Error: L6372E: Image needs at least one load region. Target not created
pls help.
So provide a base address for that region, then!
PLS PROVIDE THE CODE FOR THAT. IM VERY NEW TO EMBEDDED PROGRAMMING..
And very new to keyboard usage, so it seems!
i mean i cant find the base address anywhere.even in the datasheet its is not clear. how do i find it?
It looks as if you introduced a syntax error into the .s file. What happens if you replace it with a "standard" one (provided by Keil samples, for instance)?
