I wanted to simplify my life, so instead of creating asm function I used the __swp intrinsic provided by keil compiler.
After some time I have realized the program behaves incorrectly (making release). It was pretty dificult to find the problem. Finaly I discovered the __swp is translated differently depending on optimization level! Unfortunately, when -O3 and time_optimization are on, the __swp translates to SWPB instruction (instead of SWP), regardless of the first parameter type, thus anything above byte range is lost!
#include <stdint.h> volatile uint32_t lock = 0x12345678; volatile uint32_t t1 = 0x11111111; volatile uint32_t t2 = 0x22222222; int main(void) { for (;;) { t1 = __swp(t1, &lock); t2 = __swp(t2, &t1 ); lock = __swp(lock, &t2 ); } }
Working:
; generated by ARM C/C++ Compiler with , RVCT4.0 [Build 524] for uVision ; commandline ArmCC [--debug -c --asm --interleave -o.\obj\swap.o --depend=.\obj\swap.d --device=DARMP --apcs=interwork -O0 -IC:\apps\Keil\ARM\INC\Philips --omf_browse=.\obj\swap.crf swap.c] ARM AREA ||.text||, CODE, READONLY, ALIGN=2 main PROC ;;;6 ;;;7 int main(void) 000000 e1a00000 MOV r0,r0 |L1.4| ;;;8 { ;;;9 for (;;) ;;;10 { ;;;11 t1 = __swp(t1, &lock); 000004 e59f1044 LDR r1,|L1.80| 000008 e5911000 LDR r1,[r1,#0] ; t1 00000c e59f2040 LDR r2,|L1.84| 000010 e1020091 SWP r0,r1,[r2] 000014 e59f1034 LDR r1,|L1.80| 000018 e5810000 STR r0,[r1,#0] ; t1 ;;;12 t2 = __swp(t2, &t1 ); 00001c e59f1034 LDR r1,|L1.88| 000020 e5912000 LDR r2,[r1,#0] ; t2 000024 e59f1024 LDR r1,|L1.80| 000028 e1010092 SWP r0,r2,[r1] 00002c e59f1024 LDR r1,|L1.88| 000030 e5810000 STR r0,[r1,#0] ; t2 ;;;13 lock = __swp(lock, &t2 ); 000034 e59f1018 LDR r1,|L1.84| 000038 e5912000 LDR r2,[r1,#0] ; lock 00003c e59f1014 LDR r1,|L1.88| 000040 e1010092 SWP r0,r2,[r1] 000044 e59f1008 LDR r1,|L1.84| 000048 e5810000 STR r0,[r1,#0] ; lock 00004c eaffffec B |L1.4| ;;;14 } ;;;15 } ENDP |L1.80| DCD ||t1|| |L1.84| DCD lock |L1.88| DCD ||t2|| AREA ||.data||, DATA, ALIGN=2 lock DCD 0x12345678 ||t1|| DCD 0x11111111 ||t2|| DCD 0x22222222 __ARM_use_no_argv EQU 0
Optimized:
; generated by ARM C/C++ Compiler with , RVCT4.0 [Build 524] for uVision ; commandline ArmCC [--debug -c --asm --interleave -o.\obj\swap.o --depend=.\obj\swap.d --device=DARMP --apcs=interwork -O3 -Otime -IC:\apps\Keil\ARM\INC\Philips --omf_browse=.\obj\swap.crf swap.c] ARM AREA ||.text||, CODE, READONLY, ALIGN=2 main PROC ;;;6 ;;;7 int main(void) 000000 e59f0030 LDR r0,|L1.56| ;;;8 { ;;;9 for (;;) ;;;10 { ;;;11 t1 = __swp(t1, &lock); 000004 e2802000 ADD r2,r0,#0 ;;;12 t2 = __swp(t2, &t1 ); 000008 e2823004 ADD r3,r2,#4 ;;;13 lock = __swp(lock, &t2 ); 00000c e283c004 ADD r12,r3,#4 |L1.16| 000010 e5901004 LDR r1,[r0,#4] ;11 ; t1 000014 e1421091 SWPB r1,r1,[r2] ;11 000018 e5801004 STR r1,[r0,#4] ;11 ; t1 00001c e5901008 LDR r1,[r0,#8] ;12 ; t2 000020 e1431091 SWPB r1,r1,[r3] ;12 000024 e5801008 STR r1,[r0,#8] ;12 ; t2 000028 e5901000 LDR r1,[r0,#0] ; lock 00002c e14c1091 SWPB r1,r1,[r12] 000030 e5801000 STR r1,[r0,#0] ; lock 000034 eafffff5 B |L1.16| ;;;14 } ;;;15 } ENDP |L1.56| DCD ||.data|| AREA ||.data||, DATA, ALIGN=2 lock DCD 0x12345678 ||t1|| DCD 0x11111111 ||t2|| DCD 0x22222222 __ARM_use_no_argv EQU 0
IDE-Version: µVision V4.00 Beta 3.1 Copyright (c) Keil Elektronik GmbH / Keil Software, Inc. 1995 - 2009 Tool Version Numbers: Toolchain: RealView MDK-ARM Version: 3.50 Toolchain Path: BIN40\ C Compiler: Armcc.Exe V4.0.0.524 Assembler: Armasm.Exe V4.0.0.524 Linker/Locator: ArmLink.Exe V4.0.0.524 Librarian: ArmAr.Exe V4.0.0.524 Hex Converter: FromElf.Exe V4.0.0.524 CPU DLL: SARM.DLL V3.50 Dialog DLL: DARMP.DLL V1.44 Target DLL: BIN\UL2ARM.DLL V1.47 Dialog DLL: ARMP.DLL V1.44
Did you try to add an explicit cast to the pointer parameter of the intrinsic, like the manual suggests?
www.keil.com/.../armccref_cjahdchb.htm
Have you contacted Keil support?
Mike,
yes, I've tried both of following:
(volatile uint32_t *) (volatile int *)
Also as tried to "prolong" the first parameter type via casting (as for variables also as for constants).
Per, no, I haven't. We currently have no support bought (it already expired).
Support or not doesn't much matter. If you have found a bug, it's a bug that exists for all people who do have support contracts too. So I still recommend you to contact Keil support.
OK. Done.
