This is not a problem but a question of you C experts. I am trying to use Keil tools so I thought I would start here. The following typedef is declared in a header file that is included in a header file that is included in a header file that is included in a header file about five deep. My question is basic C. Why would the programmer use a struct of one uint16? I can understand a callback to define a table of records in non-volatile memory. Don't ask me how the programmer planned to use this code. It's not used anywhere!
typedef struct { uint16 numRecs; } nvBindingHdr_t;
By the way, the code is from Texas Instruments Z-Stack for their ZigBee CC2530 devices. Please educate me a bit. Bradford
Actually, no, it's not. It's a question about the data structure design of an (apparently somewhat involved) piece of software. The fact that it's expressed in C syntax is quite irrelevant.
That's strictly impossible to tell from such a microscopic fragment. You're basically asking for a mind reading of a person neither you or us has likely ever met.
As-is, the only conclusion to be drawn from this fragment is that somebody might have over-done the abstraction or data-hiding a bit.
One reason to hide a single integer in a struct is that the integer representation may change later, to a more complex form.
Having a struct, means that functions will take a pointer to the struct as parameter, making the code compatible even if the struct suddenly contains two integers or a string.
The time stamp you receive from time() is also intended to be different depending on environment - you call time(time_t *t) even if time_t is an integer. But since everyone "knows" that time_t is an integer, people still write code that will break if time_t changes. Had time_t been defined to always be a struct, it would have been easier to let even an 8-bit program have a 48-bit or 64-bit range even if the language doesn't have a data type of that size.
But as already noted - it's almost impossible to second-guess the decisions behind some larger body of code. Especially from that tiny fragment. Another thing - larger programs often have a bit of cruft. You may find a number of variables, data types or functions that are no longer used in a meaningful way.
Gents; Thank you both for your feedback. Per; What you write makes a great deal of sense to me. Thanks again, Bradford
