I found if I set breakpoints in assembly code, the DS-5 debugger is not trapped there on omap3530 beagleboard. In addition, it doesn't step in assembly codes, if assembly codes are in a static/dynamic libs.
I have used this option in my compiler
clicked download image, it links to same page. When you move cursor over the download image, you can see the link has no *tar file at the bottom of the browser.
On the download page, you should see two columns. In the left hand side are different categories of product, and you should select:
Software Development Tools -> DS-5 Trial
Then in the right-hand side, you will see up to three downloads:
DS-5 Trial Binary (GPL Sources) DS-5 Trial Binary (Linux) DS-5 Trial Binary (Windows)
Next to each of these is a "Download Now" link to download the files. I have found that the extension for the Linux download differs depending on the web browser you use. I originally used Chrome and the file ends with .tgz.tar. If I use Internet Explorer it ends with .tgz. In both cases, extract it the same way at a Linux shell using the gtar command.
I am not seeing your page, Here is download page I get www.arm.com/.../ds-5.php I use firefox.
I can now reproduce this. I think this is a problem with the website. The solution is to logout using the button in the top-right corner of the page, then log back in again. After this you should reach the download page that I described before.
It's the web browser that adds .tar if it thinks the mime type for the file suggests it is a tar file.
It's a common problem with compressed tar files.
I just tested the new release. It has same issues as before, no register, no stack frames in assembly code and it doesn't step out. Are they tested OK in windows environment?
The DS-5 releases are tested on various versions of Windows and Linux both 32- and 64-bit.
For Linux hosts, the primary platform is Red Hat Linux Enterprise 5 for x86 (32- & 64-bit). They have also been tested some on Ubuntu 9.10 64-bit, but it's not officially supported yet.
I tested DS-5 in Windows Vista, there are still no frame stacks in assembly codes except registers view.
Here are some more suggestions to help resolve the lack of registers problem.
The debugger uses a database to hold information about which registers to make available for each processor and board.
The location of this database can be found in the Eclipse Preferences dialog (select Preferences from the Window menu), and then navigate to DS-5 Debugger -> Target Database. Check that this location exists. As I mentioned in a separate post, if you delete all the files in this location then they should be automatically regenerated the next time you try to connect using the debugger.
In the Debug Configurations dialog where you configure connections, can I also check what values you have for Platform, Project type and Debug operation. You could also try deleting your configuration and creating a completely new one.
