I have some problems with debugging peripherals of my STM32F103VC. I implemented a simple counter by using Timer 5 of the µC named above. The Timer seems to work and I can read out the value of the Counter Register (TIM5->CNT). When i started the Debug-Mode of µVision3, i can't find the Timer5-Item in the "Peripherals Menu". The called controller should even have an SPI3, but i can't find this peripheral in the Peripherals Menu, too. I don't understand this behaviour, because i have chosen STM32F103VC at the device manager. Smaller controllers are presented correctly...
I'm using the following Development Environment running under Windows XP SP3:
IDE-Version: µVision3 V3.62c Copyright (c) Keil Elektronik GmbH / Keil Software, Inc. 1995 - 2008
Tool Version Numbers: Toolchain: RealView MDK-ARM Version: 3.23 Toolchain Path: BIN31\ C Compiler: Armcc.Exe V3.1.0.939 Assembler: Armasm.Exe V3.1.0.939 Linker/Locator: ArmLink.Exe V3.1.0.939 Librarian: ArmAr.Exe V3.1.0.939 Hex Converter: FromElf.Exe V3.1.0.939 CPU DLL: SARMCM3.DLL V3.22f Dialog DLL: DARMSTM.DLL V1.34 Target DLL: BIN\UL2CM3.DLL V1.41c Dialog DLL: TARMSTM.DLL V1.33
We use the application library of ST at the Version of 2.0.3.
I hope there is anybody, who can help me.
Thanks...
You are using UV3, and even in UV4, this device is not fully simulated.
Please see this: http://www.keil.com/dd/chip/4226.htm
Simulated Features
NOTE Simulation for this device is provided by the default peripheral simulation driver.
Complete peripheral simulation is not available at this time.
