Does the realview arm compiler support the following syntax:
#pragma pack(push, 1) and #pragma pack(pop)
or do I need to separate it into
#pragma push #pragma pack(1) and #pragma pop
There are no compiler warnings given for the former, but I'm having some issues with unaligned memory accesses on some ported code.
Also what happens when you do
#pragma pack()
with no parameter, will it revert to the default (8)?
