When ISR calls os_mut_wait() the processor generates an exception.
Is os_mut_wait() prohibited from being called from an ISR?
It shouldn't be necessary to prohibit that. It's self-evident that it's a Very Bad Idea, Indeed(TM), to sit inside an ISR waiting for some other part of the system that can never be reached from this situation to release a Mutex.
Then, what is a good way to share memory between the ISR and and lets say a get funtion?
There are two approaches that would work great. The first is a mutex mechanism. The second is turning off the interrupt source. In this case disabling the interrupt source would be the best because I don't know how os_mut_wait() is written. Is it written to disable interrupts?
The first example:
///< Global Counter I32U Counter = 0; ///< Mutex used between ISR and Get function OS_MUT mutex; /************************** * Initializes Values **************************/ void Init(void) { os_mut_init(mutex); } /************************** * Returns Counter Value **************************/ I32U GetCounter(void) { I32U value; // Lock the mutex os_mut_wait(mutex); // Now, Get the value value = Counter; // Release the mutex os_mut_release(); return value; } /************************** * Returns Counter Value **************************/ void TimerISR(void) { // Lock the mutex os_mut_wait(mutex); // Now, change the value ++Counter; // Release the mutex os_mut_release(); }
The second example
///< Global Counter I32U Counter = 0; /************************** * Returns Counter Value **************************/ I32U GetCounter(void) { I32U value; // Disable the timer TIMER = DISABLE; // Now, Get the value value = Counter; // Enable the timer again TIMER = ENABLE; return value; } /************************** * Returns Counter Value **************************/ void TimerISR(void) { // Now, change the value ++Counter; }
The "good" way is to use a ring buffer, where the ISR (producer) owns the write pointer and the main program (consumer) owns the read pointer.
Suddenly, you don't need any locking mechanisms unless your processor isn't able to perform atomic writes of the pointers.
You may decide to degenerate the ring buffer into a double-buffered approach too if you want.
But the ISR may never wait. It must always be able to go ahead - or must be delayed a clock cycle or two from entering - or must fail.
"Is os_mut_wait() prohibited from being called from an ISR?"
Yes, it most definitely is.
Quote: "Functions that begin with os_ can be called from a task but not from an interrupt service routine."
www.keil.com/.../rlarm_ar_using_hints.htm
