I NEED WORKING DIY PROGRAMMER FOR '51 with sch and software
I have lot of search on google and this forum but here i mean working programmer at this forum .so i can made without trouble. so next time i start old topic as advice.
Do you really believe somebody in eager to hear you "advice"?
YOU think THAT IS the answer f0r my question???????
No.
"I NEED WORKING DIY PROGRAMMER FOR '51"
So why did you specify the architecture as ARM?!
" i mean working programmer at this forum. so i can made without trouble"
There's the fundamental problem: you cannot know that it works if you've built it yourself!
If you want to know that it works, you'll have to buy one ready made & working!
i mean working programmer.so i can made without trouble. 1) no two derivatives program the same way 2) there has been 4711 threads in various fora "why does the programmer I made from the web not work" )3 ABANDON THE IDEA and use ISP chips which need no 'programmer' xxxRD2, SILabs chips LPC3xx, LPC4xx, LPC5xx ......
how do you propose to make a '51 programmer for ARM?
No, you don't. Nor do you need to YELL at us. Nor do you need to specify ARM as the architectur when you're about to ask a question about '51s.
For starters, there's no such thing as generic as a "programmer for '51", because there are a gazillion different '51 devices, and practically every one of them uses a different programming technique. There are commercial programmers that can programming practically any '51 on the market --- but that's because these things can program anything.
If you have to ask, you can't do it. Not without trouble, anyway. The fact that you have to ask is trouble already.
Frankly speaking, it's rather doubtful that anyone here particularly needs your advice.
