I want to use two dimensional array on realview compiler with type A[n][10] where n is an variable of type unsigned char. but it show an error.
That's because you cannot do that. Arrays must have a predefined size during compilation, unless constructed at runtime using dynamic memory allocation. Please have a look at a fundamental C programming language study book.
And what error, exactly, did it show?
#28: expression must have a constant value
my code example is unsigned char n; unsigned char A[n][10]; function { n =5; A[1][0] = 2; A[1] [1] = 4; }
Which is, as Tamir said, a basic factor of the way that arrays work in the 'C' programming language!
how to allocate dynamic memory for two dimensional array in c in realview compiler
The dynamic memory allocation just allocates memory - it neither knows nor cares how you're going to use that memory.
So just look-up "dynamic memory allocation" in the Realview compiler Manual...
Before talking abou Realview specifics, you do know how to do this in plain, ANSI 'C', don't you...?
Note that dynamic memory allocation is often best avoided in embedded systems.
What, exactly, are you trying to achieve here?
If you explain what you're actually trying to achieve, people may be able to offer better approaches - rather than just discuss a potentially broken approach...
at the time of compilation , i do not know the size of multidimensional array that's why i want to know about dynamic memory allocation for two dimensional array in realview compiler
"at the time of compilation , i do not know the size of multidimensional array that's why i want to know about dynamic memory allocation for two dimensional array in realview compiler"
You were asked to explain what you are actually trying to achieve. Using a 2D array of unknown size may or may not be a good way to do what you need - but nobody can comment on that without knowing what, exactly, you are actually trying to do!
Dynamic memory allocation requires that the processor do have the required amount of memory.
That also means that you could instead define a maximum allowed size, and create a statically allocated array of this maximum size.
If you can't afford to waste the memory for a static allocation of maximum allowed size, then it is very questionable if you can afford to allocate such an amount using dynamic memory, unless your program have two types of memory requirements, and when one of them needs to be large, the other will instead always manage with a small size, and reverse.
Another thing. Sometimes it is good to use a two-dimensional array. Sometimes it may even be better to have a one-dimensional array, and have the application select this single index based on the the two original indices. Note that the code generated by the compiler will somehow have to compute (I*stride + J)*element_size internally, when mapping into a specific element. But the one-dimensional array allows you to change the stride size during runtime. You could have a 100*10 array or a 10*100.
"when one of them needs to be large, the other will instead always manage with a small size, and reverse."
In which case you may be able to use a statically-allocated union...
Note that my comment was about dynamic memory allocation - that the only situation where two static variables of maximum size doesn't fit, but two dynamic allocations fit, is if one of the dynamic calls is large when the other is small, i.e. the two variables following some form of A*N and (M-B*N).
For situations where both dynamic allocations are large, then neither dynamic nor static allocation can solve the problem. For situations where both allocations are small, it will be trivial to use static allocations instead.
For the case when one variable needs to be large when the other is small, I wouldn't try to use a union and definitely not traditional dynamic memory. I would instead use a fixed-size memory block and set a pointer x bytes/elements into the block for the second variable, thereby allowing me to configure the subdivision position depending on runtime information. Since the block has a fixed size, I would be able to compute beforehand if the two variables will fit after each other, instead of having to test a dynamic allocation and check for a NULL pointer. And I wouldn't need the overhead of the dynamic memory allocation/release code. And the code can't suffer from fragmentation.
A union would be a bit boring, since it would be something like:
union { struct { small_A, large_B; } alt_1; struct { medium_A, medium_B; } alt_2; struct { large_A, small_B; } alt_3; ... };
where the code may need a large number of in-between subdivisions, and would then need code to - at run time - gets access to alt_1.small_A, or alt2.medium_A, or alt3.large_A, or ...
