Hello again,
I need an 8051 variant which can handle USB2.0 (Full or High-Speed) and has a full 16-bit external address space (w/ data-bus of course): I shall be bank-switching for a 2Mx8 storage area.
I don't mind splitting the design into a small (very small USB to UART) mated to a high-pin-count 8051 flavored IC. Naturally power-consumption is a huge issue: LOW POWER.
I was going to use ST-Microelectronics uPSD3454x but they are discontinuing it. Now I must convert the design over to a [production] part.
I concidered using Actel's FPGA with embedded Core8051 or Cortex M-1, but the demanding qualities of the project prohibit that avenue at this time.
I've been looking at SilLabs, yet many of the bells-n-whistles aren't needed.
Requirement 1.0 --------------- Low Power--Battery Operated with USB charge capability
Requirement 1.0.1 ----------------- Sleep Mode, and Power-down mode (wake-up on NMI)
Requirement 1.0.2 ----------------- Capable of data-logging for 24+ hours at 'full operation'
Requirement 1.1 --------------- Needs to address up to (and maybe more than) 2Mx8 external low-power RAM
Requirement 1.2 --------------- USB is the primary mode of PC\device communication. Requirement 1.2.1 ----------------- USB 1.1 would suffice for such low content (2Mx8)
Requirement 1.3 --------------- Capable of interfacing to an FPGA for dual User Graphics 162 x 96 [each] engine
A low-power ARM [Cortex] would be a possibility, but I think it is over-kill.
Q1) What is a high-pin count, low-power 8051 with Flash (64k would be nice)? Q2) What is the smallest and lowest power USB to UART device.
I figured that erik, per, Andy, and Tamir might have a quick answer... and not the Keil parametric search.
Sincerely,
--Cpt. Vince Foster 2nd Cannon Place Fort Marcy Park, VA
slave or master?
The data-logger is a slave to the PC which connects via USB.
use a FTDI chip (maybe through a few tristateable gates) power the FTDI chip from the USB and, effectively, you have a device that only uses power for the logging.
I was assuming a device that runs from battery when logging and then is (transported to and) connected to the PC for readout.
yes, it is battery operated, and the data collected goes to a PC for Post Analysis.
I'll investigate the FTDI Chip for the USB end of the schematic.
Thanks for your help. Now I need to find a uC that can handle SPI/I2C/UART and 16+ Address/data lines. I have room for a 100 QFP device: and an Actel IGLOO graphics chip to off-load the CPU from the graphical updates.
Thanks again.
I do not know if any will satisfy your needs, but the '51 misers I am aware of are TIs '51 derivatives and some of the SILabs chips (noteably f9xx). I guess you have figured to put the processor to sleep between measurements. Running the cips at as low a clock as you can get by with and at the minimum Vcc really makes a difference.
ps is it misering, misery, mising ???
I emailed FTDI with the criteria I need, and hopefully they'll get back to me with the exact device I need.
Again, thanks for your input erik.
I chose the Silicon Laboratories C8051F131 (100TQFP) for the main controller. And a Cypress CY62168EV30 MoBL 2Mx8 Static RAM. The FPGA shall be the Actel IGLOO nano AGLN250V2-ZVQG100 to make the dual LCD graphics controller.
Thanks again erik.
Wow. That sounds like a mix of technologies spanning 30 years (from 8051 to modern SRAM and FPGA.) The 8051 simply won't die, right? :-)
I would not use static RAM, what if the battery runs out? there are flash chops availibale such as 2M*8 that - for write nd read are almost RAM compatible. That the flash need be erased after a readout should not hurt your app
The data will constantly change, so Flash won't work. Constant data compression shall be occuring. Even wear-leveling won't help. It must be sRAM based.
P.S. Yes, the 8051 core shall do the job. It shall live forever. In this application, horse-power (MIPs) aren't the issue, but rather power consumption. IF an ARM was capable of low-power with a high-pin count, then I would consider it. Eventually, I'll suck the 8051 core into the FPGA after LRIP (Low-Rate-Initial-Production).
But what is your power budget for the processor? A number of ARM has quite good performance too, since they are often manufactured using more high-end technologies.
Have you looked at F-RAM memory? Did you reject them based on current consumption?
Hey Capt; Sounds like another fun project. I used the SiLabs F340 as the USB engine for legacy reasons. The client had lots of software running and a pretty good USB interface. The F340 has the ability to present a 16 bit address non-multiplexed but still only an 8 bit data path.
We had lots of high speed FPGA fabric to create our pattern generator outputs. I interfaced the F340 16 bit address lines to Block Ram on the Xilinx FPGA. The four LSB address lines selected one of four bytes of Block Ram. I use only 32 bits but the Xilinx IP for the external interfaced Block Ram demands the full four bits as the minimum.
I used additional FPGA GPIO as my port expander for GPIO not supported by the F340. My need to write pattern data from the USB via the F340 is not super fast but I created two Block Ram storage areas in the FPGA and ping/pong the data from the F340 to the FPGA. I can change an output pattern on the fly with no loss of resolution.
I still suggest that you look at the Stellaris devices. For low current, low cost and big bit crunching, you can't beat some of the Stallaris chips.
A typical Stallaris LM3Sxx starts at $2.70 US in qty of 1! No USB on that chip but there other chips with more RAM/Flash, USB OTG and Device at Full Speed. Cost run under $10.00 in small qtys. Also, Stellaris supports their chips with a lot of good code examples free of charge.
Why did I not implement USB on the FPGA?? Cost of the USB IP core was a lot more than mounting the F340 plus the legacy code issue.
Good luck and keep us posted on your project. Bradford
Capt; I just remembered another simple project. I used the low cost Stellaris interfaced to a SiLabs CM2400 LCD driver. Worked great for a low cost non-critical project. Bradford
I'd just like to add emphasis to that:
It is a sad fact that a great deal of the free examples provided by all too many suppliers are very bad - see rant here: www.8052.com/.../174319
I think the Stellaris examples are not only good examples for (potential) customers trying to use their chips - they should also be studied by other manufacturers as examples of how to write example code!
