I have an asm file that generates a “WARNING L5: CODE SPACE MEMORY OVERLAP” message.
If I add the following line at the top of the code it compiles OK:
CSEG at 0x4000
But I want the linker to allocate the address so I tried the following:
CSEG
But the warning came back as the asm code is located at 0x0000.
The rest of my project is in “C”.
How do I get the linker to relocate my asm to an unused area of memory?
Terry
and do you have other CSEG statements with addresses in them?
Are you using the evaluation tools? Read the restrictions on the the eval tools. Bradford
Full version protected with a dongle.
uVision3 V3.05c A51.exe V7.10 BL51.exe V5.12
I only have one asm file with one CSEG + lots of C files.
I've worked out what the problem was.
For some reason my asm file was at the end of the obj list in the lnp file so it was linking first.
Putting it at the end fixed things.
I have used CSEG before and sometimes I got odd warnings or errors from the Linker. I can't remember if I got the exact one you mention but my solution was:
Add the option NOOL to Misc controls in the BL51 Misc Tab in Option for your project. This means No-Overlay, sometimes I think the Linker has trouble working out if one function is called by another and this stops it from trying. It used more memory but solved my problem.
Hope it helps PhilipJ
