uVision 4 External RAM Configuration Problem STM32f10x
I am using a STM3210E-EVAL baord with uVision4 as my development tools.
There are project configuration Options for the Target where "Read/Write Memory Areas" can be defined. For the STM3210E-EVAL there is external RAM starting at 0x68000000. There is 512KbitX16, which is about a 1 megabyte (0x100000).
After enabling this external memory area the processor will not jump to main. Why would this not work? The "NoInit" check box is not set.
  • Hi,
    did you make sure that it not jumps to an abort?
    If peripherals are not (properly) enabled, the processor could jump to an abort handler.
    See startup.s file in project.
    BR,
    /th.
  • The processor jumps to the HardFault_Handler routine. However, this is after going into "__main". I'm not exactly sure what is inside of "__main". There is a startup file in 'C:\Keil' that shows the following:
    ; Dummy SystemInit_ExtMemCtl function
    SystemInit_ExtMemCtl     PROC
                    EXPORT  SystemInit_ExtMemCtl      [WEAK]
                    BX      LR
                    ENDP
    ; Reset handler routine
    Reset_Handler   PROC
                    EXPORT  Reset_Handler             [WEAK]
                    IMPORT  __main
                    LDR     R0, = SystemInit_ExtMemCtl ; initialize external memory controller
                    BLX     R0
                    LDR     R1, = __initial_sp        ; restore original stack pointer
                    MSR     MSP, R1
                    LDR     R0, =__main
                    BX      R0
                    ENDP
    What is suppose to go into 'SystemInit_ExtMemCtl' assembler routine? I have a fsmc_sram.c file that performs this intialization.
    What happens inside of '__main' when you specify off-chip memory?
    Where could I find this information?
