can someone show how to put analog levels on output {like port pin 2} at two or three multiplies of input {like port pin 6}?
what?
i said. can someone show how to put analog levels on output {like port pin 2} at two or three multiplies of input {like port pin 6}?
Come again?
you need to state more clearly what you want
using more words does not make you appear stupid, it makes you appear clear
But we have absolutely no idea what you mean by it!
So there's no point in just repeating it verbatim!
Remember: nobody knows anything about you, your background, or your project other than what you clearly & explicitly state in your posts!
So you want to read an input, multiple by 3 and output the results. So what device are you using? Does it have Analog inputs and outputs? Do you have a target board? Are you trying to simulate? What Keil tools are you using? What have you attempted to code at this point? Do you see that you have given no useful information or ask real questions at this time? Bradford
