My ADuC7026 wont transmit more than the I2C address byte when trying to read from a 2416 EEPROM memory. The SCL and SDA looks sensible on the 'scope, but I don't know whether it's the hardware or the software. The code is based on the examples and looks like this:
uint8_t Byte_Read(const uint16_t EEPROM_Address) { uint16_t block; bool wait; uint8_t res = 0xffu; uint32_t reg; // Fish out the block address block = (EEPROM_Address & 0x0700 ) >> 7; // Fill FIFO with Destination Address low bits I2C1MTX = EEPROM_Address & 0x00ff ; // Set Address Write Command with merged block address I2C1ADR = SLAVE_ADDR_W | block; // What until Master is finished command do { reg = I2C1MSTA; // take a copy as some bits are cleared by a read wait = (bool)((reg & I2CMSTA_Busy_Mask ) == I2CMSTA_Busy_Mask); } while(wait); if(I2CMSTA_NoAck_Mask == (I2CMSTA_NoAck_Mask & reg)) { res = 0xfeu; } I2C1CNT = 0; // Read a Single 8 Bit Byte I2C1ADR = SLAVE_ADDR_R | block; // Transmit read Address setTickTimeout(TIdx_I2C, READ_TIMEOUT_MSEC); // start a timeout timer // Wait until Master recieve data, i.e. RXIrq set do { wait = (bool)((I2C1MSTA & I2CMSTA_RXIrq_Mask) == 0x0); wait = wait && !(tickers[TIdx_I2C].flag); // check the timeout timer } while(wait); if(I2C1MSTA & I2CMSTA_RXIrq_Mask) { res = I2C1MRX; // Read Data Read } return res; }
Trying to find a software bug when your problem is actually hardware is never going to be productive.
