HEy we have designed our own 8051 board using 4066 to convert single serial port to 4 port but gives lots of garbage once we power up
Cool. Are you offering to share the design?
Design is not with me its with my boss.... I am working on this. Its simple rx and tx pin of 8051 is connected to 4066 and from 4066 to max232, data is sent to outside world by selecteing control signal to which are connected between 8051 and 4066 It works fine with all serial device except serial device (like printer)
Is there a reason that you have an analog switch for multiplexing one-way digital signals?
Is there pull-up/pull-down resistors on the signals - what happens with the signals for the unused serial ports when you mux to another port - does the signals float or are they forced to a good logic state?
thanks for your reply, all control signal(analog switch 4066) are on P2 port whcih has internal pull up. the signals for unused signal are grounded
I'm not just talking about control signals. I'm talking about the RXD and TXD signals, and optional handshake signals.
P2 is one side of the 4066. What about the other side - the signals on the MAX232 that are sometimes isolated from the 8051 chip? What will the logic-level inputs on the MAX232 see when the processor is busy with another serial port?
I am not getting what want u to ask can u explain me with some diagram or any reference...
as I understood when 1st port is enabled then second port signals that are RXin and TXin are left open
I have no idea what micro (u) asks, but what Per ask is: "what goes out on the RS232 lines of the disabled channels (which will have floating inputs)". I agree with a previous poster that it is a mistake to use an analog switch for the logic level Txd and Rxd signals.
What will keep the input to the MAX232 at a logic high, or logic low, level when the 4066 disconnects the processor output pin (with the internal pull-up) from the MAX232?
8051 ---------+ + | | | +-+ | | | | 4066 MAX232 | | | +-------+ +------+ +-+ | | | | | | | | / | | | TXD -+---|--+--|--o o-|----|------|--o RS232 TXD | | | | | | | | | | | | | | +-------+ +------+ ---------+ | | 4066 MAX232 | +-------+ +------+ | | | | | | | | | | +--|-o--o--|----|------|--o RS232 TXD | | | | | | | | +-------+ +------+
You have one TX output from the processor.
You have multiple MAX232.
Only one external serial port will be connected at a time to the processor TX signal.
That means that the TXD pin on your processor can only maintain a correct logic level on one (1) MAX232 input. What about the other MAX232 inputs? When the 4066 disconnects, these signals will be floating unless you have added a resistor for each multiplexed MAX232 logic-level input.
A solution with digital multiplexing means that the multiplexer chip can drive multiple outputs even if only one of the ouputs are connected to an input.
The 4066 has bilateral (dual-direction) switches - one side will see pull-up/pull-down from the other side when the switch is closed. But will not see any reference when the switch is open.
I think the CD4052 is more batter than CD4066. Or use a data selector.
I think the CD4052 is more batter than CD4066. no difference, equally lousy for this purpose Or use a data selector. Use regular HC logic gates
so please tell me which multiplexer to be used to solve this Issue... or any thing I can modify in existing schematic
You haven't shown the existing schematic - so how can anyone say how to modify it?!
an '00 and a '02 you need a total of 7 gates (1 3/4 chip). if you are willing to spend two port pins you can get by with 6 gates.
you can use one '58
Hi Andy, hey I want to send my schematic but how to send word document as an attachment...
