Can anyone provide me the working code of interfacing of any ADC (preferably MCP3208) and LPC2378 or LPC1248 using SPI? My below code is not working
this is my main pgm:
int main() { Init_2378(); //Initialisation of internal peripherals while(1) { IOCLR0 = CS_ADC; //CS Enable spi0_send_Byte(0x064);/*12 Bit of Data with start bit, configuration bits (D2 D1 D0)*/ spi0_send_Byte(0x000); //Dont care bits ADC_Value = spi0_receive_Byte(); /*reads value from SPI bus SOSPDR*/ IOSET0 = CS_ADC; //CS disable putchUART0(ADC_Value>>8); //output on UART putchUART0(ADC_Value); } }
This is my SPI Initialisation code
void SPI0_Init() { // set up SPI0 //P0.15 (SCK), P0.16 (SSEL), P0.17 (MISO), P0.18(MOSI) PCONP |= (1 << 8); //On SPI PINSEL0|= 0xC0000000; //SCK P0.15 PINSEL1|= 0x0000003F; //SSEL, MISO, MOSI IOSET0=CS_ADC ;/*disabled SSEL =1 Chip Select is active low hence set*/ S0SPCR = 0x0C24; // master mode, CPHA = 0 CPOL = 0, MSB first, 12 bits of data transfer S0SPCCR = 0x0C; // this makes the SPI0 bus 1Mhz // (PCLK/12 (0x0C) = 12Mhz/12=1.0) //on reset SPI is enabled } void spi0_send_Byte(unsigned int buf) { unsigned int dummy; S0SPDR = buf; while ((S0SPSR & 0x80) == 0); /*wait till SPIF (7th bit) is 0, when SPIF=1 SPI Data transfer is complete*/ dummy = S0SPDR; //dummy read } unsigned int spi0_receive_Byte() { unsigned int value; S0SPDR = 0xFFFF;/* write dummy byte out to generate clock, then read data from MISO */ while ( !(S0SPSR & SPIF) ); value=S0SPDR; return(value); }
The above code transmits max. value of ADC continuously i.e 0F FF (4095) I am using Channel 1 of ADC and i have connected a 10K pot at input. I dont get any variation in the output of ADC.
Hey guys my ADC started working!! I was doing one mistake....! I was defining P0.16 as SSEL (Slave Select Pin), but it is required to define this pin as a GPIO Pin (declared as output) and not as SPI SSEL pin. The above code is same with only few changes as below-
PINSEL1|= 0x0000003C; //GPIO, MISO, MOSI
and in the main program, no need to send Dont care bits for ADC -
int main() { Init_2378(); //Initialisation of internal peripherals while(1) { Delay_ADC(10000); IOCLR0 = CS_ADC; spi0_send_Byte(0x064);//12 Bit of Data ADC_Value = spi0_receive_Byte(); IOSET0 = CS_ADC; putchUART0(ADC_Value>>8); putchUART0(ADC_Value); } }
