Target Platform: LPC2119 and TJA1040 CAN transceiver. IDE : Keil uVision 4 Error: CAN Controller fails to transmit message. Debugging Devices Used: Keil ULink and Oscilloscope.
Steps to reproduce the error: 1. Store a CAN message in the Tx Mailbox of the CAN controller. 2. Set the Command register to transmit the message. 3. Do a while loop until global status register receives update of either "transmission success" or "transmit error counter reaches its limit".
Expected Behaviour to be observed by Keil Ulink on-chip Debugger: The global status register is updated of transmission success or transmission error counter reaching its limit.
Actual behaviour observed by Keil Ulink on-chip debugger: The program keeps running in the endless loop as described in step 3.
Expected Behaviour to be observed by oscilloscope: Waveform coming from CANTx Pin of LPC2119 to the other end at the CAN transceiver.
Actual behaviour observed by oscilloscope: No waveform is observed from CANTx Pin of LPC2119 to the other end at the CAN transceiver.
Remark: I have tried both my own program and MCB2100 BlinkyCAN example program from Keil on more than 3 LPC2119 microprocessors; all fails to transmit CAN messages. On the other hand, functionalities such as RS232 work perfectly on LPC2119.
Any advice is welcome. Thanks!
