I have a Keil MCBSTM32E board and I have couple of Motors connected connected to this board via some drivers.
Every time I update the Board with new flash image the motor run for the duration of the update. I am making use of a ULINK2 on the JTAG to update the flash image.
Its not just the motors even the LED's stay on. I guess it has to do with all I/O or more specifically output ports.
Is there a way to get around it ?
MCU is reset before flashing starts (flash algorithms rely on this) and therefore all I/O pins are defined as Floating inputs (on STM32). State of I/O pins is therefore defines by external connections to the MCU. Once the program is flashed and starts running it will configure the I/O pins.
You could use pull-up/down resistors on the motor drivers to define the logic level when MCU is not driving the pins. It is anyway a good idea to define the motor driver pin levels when MCU is reset.
