LPC17XX memory configuration
Hi All
Using uVision3 V3.90, I found that the SRAM setups for some of the LPC17XX parts are not correct when taken from the target settings.
Eg. The LPC1756 has 32k of internal RAM. 16k is in local RAM (0x10000000) and 16k is in peripheral RAM (0x2007c000). See the data sheet:
ics.nxp.com/.../lpc1751.lpc1752.lpc1754.lpc1756.lpc1758.lpc1759.pdf
In the target setting in uVision3 it is selecting 32k in local RAM, which will fail due to the SP being set incorrectly and also if memory use overflows.
Regards
Mark
http://www.uTasker.com
