i m using c51 microvision4....i have a simple program using logical bitwise operator .here is d part of d code...
#include <stdio.h> void Display_Byte(const unsigned char); int main() { unsigned char x = 0xFE; unsigned int y = 0x0A0B; printf("%-35s","x"); Display_Byte(x >>= 4); return 0; }
void Display_Byte(const unsigned char CH) { unsigned char i, c = CH; unsigned char Mask = 1 << 7; for (i = 1; i <= 8; i++) { putchar(c & Mask ? '1' : '0'); c <<= 1; } putchar('\n'); }
bt while running this code icons like step one line,step over current line gets deactivated..and program doesnt work.it stays dr only..same happens for other program where i used printf and if it works where i will get to see output?
So, have you read the documentation for printf to ensure that you are using it correctly?
In particular, are you sure that you have corectly implemented the support for your particular hardware...?
Hi Pratibha,
I think you have written wrong format of printf.
It should be
printf("%-35c",x); (if x is char)
i think printf in serial window, first u can initialise serial communication then only printf works.
hai
After starting the timer (TI=1) gives this after printf works.
thanxxxxxxx a lot.......i didnt knw this...when i intialized serial communiacation routine i gt d output in serial window uart#1....
