Question in it, how can I do it? Because in Debug window I can't select this device((((
.. you configure the emulator. The emulator manual should tell you
Here: www.phyton.com/.../Keil_uVision.pdf and here http://www.keil.com/pr/article/1075.htm writing, what PICE-52 integrated with Keil uVision debugger, but how configure uVision for work with this emulator?
.. you configure the emulator. The emulator manual should tell you I can't find((((
CodeMaster-52 don't support new Keil uVision 4!
