What is the recommended size for Supervisor, Interrupt & User/System Mode Stacks when using RTX? The first stack-relevant action, the application does is "os_sys_init". From there on everything happens under the control of RTX. Regards.
Hi, reading the documentation often gives an answer: http://www.keil.com/support/man/docs/rlarm/rlarm_ar_hints_arm.htm
