Ethernet-problem
Hallo
I use the Arm Real-Time Library Version3.70.
I want to send data between a PC and a MC (LPC 2294).
If I send data from the PC to the MC is all ok, but if the MC send to the PC the data packet don't arrive correct to the PC.
I have two questions:
1. I want in the client routine receive data from the PC. I don't know in witch variables the data from the PC arrives.
2. Give it in the tcp-callback function from the client routine a case command to check if the data from the MC send accurate to the PC.
THX
  • If I send data from the PC to the MC is all ok,
    It's hard to believe you know that for a fact, given you don't seem to know how to check if anything actually arrived at the microcontroller's end of the link:
    There are not really any "variables" of that kind. Data arrives in registers, which are part of the hardware.
    I suspect the meaning of whatever you wanted to say bounced off the language barrier. I must have seen Babelfish get translations better than that, 15 years ago!
