Hi
I have specific problem compiling the file "portmacro.h" from the freeRTOS source code. I get several errors, but once I get to solve at least a few, I think the rest is just some kind of repetition. E.g - I get the following error:
.\Source\include\..\..\Source\portable\Keil\ARM7\portmacro.h(142): error: #40: expected an identifier .\Source\include\..\..\Source\portable\Keil\ARM7\portmacro.h(142): error: #666: "asm" must be used with a function definition
trying to compile the line 142 of the portmacro.h file: (140) __asm{ LDMIA SP!,{R0} };\ \ (142) __asm{ STMDB R0!, {LR} }; /* Push the return address onto the stack. */ \ (143) __asm{ MOV LR, R0 }; /* Now we have saved LR we can use it instead of R0. */ \
I guess the errors relate to the specific assembler syntax and registers, but any help will be highly appreciated!
Thanks in advance /Uffe Lunddorf
