A program which is compiled with LPC2129 as target in 2 different PC's
shows 2 different modes
one with user mode when loaded in controller, it is working
the other with supervisor mode is not working
please guide me in this case
Are you sure that the Project settings are identical on both PCs, and that both PCs have identical versions of all tools, libraries, etc...
you need to provide more details: what EXACTLY do you mean "shows 2 different modes"? what happen just before that?
problem is with PLL
PLL_CFG is not loading
and processor clock is just 12Mhz and it is not 60Mhz as in a working example
how to sort it out
i am using simulator to debug this problem
So, it works on one PC, but not on the other - doesn't that suggest an obvious way to proceed...?
Thank you very much for your assistance
the issue was in the linker tab
"use Memory Layout from Target Dialog" check box is not checked
in the latest version 3.80a doesn't check this box by default
this is where i am little confused
thank you
