ERIK,,,,,HI, I WANT 2 ASK U IF U CAN HELP ME WITH THE MONDIFICATION OF SOME PROGRAM CONSTANTS IN URE COMPLIELED EXECUTABLE,,,, THE PROGRAM HAS LIMITATIENS WITCH IS HARDLY CODED IN THE ECXECUTABLE BUT I AM NOT FAMILYAR WITH EXECUTABLS AND WANT TO START LEAR SOMETHIN NEW. THE SOFT WEAR COULD BE HELPFULL TO ANY OTHER MEMBERS OF THIZ FORUM, BECOZ ITS AN EEDA OLD SOFTWARS DEVELOPED BY ME.
You want to batch a binary to get a demo or limited version of a program to become a fully-functional version?
By the way - why SCREAMING. A malfunction of your keyboard? First try to patch the keyboard processor to automatically release capslock if it has been stuck for more than say 30 seconds.
1) press "caps lock" and it will release
2) PROGRAM HAS LIMITATIENS WITCH IS HARDLY CODED IN THE ECXECUTABLE pay for the full version
"You want to batch a binary [...]" should of course have said "You want to patch a binary [...]"
Where is the edit function?
ERIK,,,,,HI AGIN, I WANTED 2 ASK U IF U CAN HELP ME WITH THE MONDIFICATION OF MY PROGRAM I AM WRITEN,,,, THE PROGRAM HAS CODE AND I MUST LERN TO CHANGE IT.
First, You must learn to use the Caps Lock key correctly!
Do not write in ALL CAPS: it is hard to read, and is often considered to be SHOUTING - and, hence, rude.
Also, you will improve your chances of getting serious help if you make the effort to use full words - not SMS abbreviations like '2' for "to" and 'U' for "you"
Are you and Erik buddies or what? why don't you just ask (in lower case please) your question, instead of repeatedly preparing us for the exciting news? Or, maybe you are a dumb troll?
since you have written it, use any editor on the <b.source code
ERIK,,,, THX 4 UR REPLY ERIK., I WANT TO NOW JUST ASK FOR THE DISESM TOOL IS BEST FOR BEGINING, I FOUND SOME BUT U KNOW BETTER??? CAN SOME OF THE TOOL DO THE IDENTIFYCATION OF CODE WITH OFSETS TO MEMRY??? FROM WHERE T VARIS IS READ??? I KNOW THAT IS NOT EASY, BUT IS IS A TEECJING CHALENGE FOR ME AND GOOD 4 U.
Yes, we know about better disassemblers. And yes, good disassemblers can handl code with offsets to memory. Not sure if a disassembler that can't is worthy of being called a disassembler.
I hereby declare you as a troll.
THX 4 UR U 4 U.
d r s b i t y r t t s sw
