Re-Post on INT
Guys sorry for my poor format for the same issue previously....
Hey Linq,
A good news infact for your valuable support , today I was able to comunicate with I2C , almost 90% is done . Can you help me out for these issues listed below ..
the state where i get data ,i.e
case 0x50 ( Data Recieved with ACK) :
Master_Buff[Read_Index] = I2DAT ;
Read_Index++;
if(Read_Index != MAX_READ)
   I21CONSET = 0x04 (ACK bit)
else
Read_Index = 0;
I21CONSET = 0x10 (stop)
When I track Master_Buff 's value and use it within the Interrupt using UARTBYte out under CASE 0x50 , i get the correct data .
When I track Master_Buff''s value outside the IRQ and use it in my main , i am not getting the data .
To be noted that Master_Buff is a global variable , Then where should be the problem ???
Thanks for your support !
Looking forward,
Samjith
