Problem using serial window #1
can any body help me in using serial port window. I am trying to input data in hexadecimal format. Tell me how to input data using serial port window. As i am trying to campare two arrays
  • What do you mean by "comparing two arrays"?
    An array stored in the memory of the microcontroller will have binary data so if you send data to the serial port as two ASCII characters, you will have to write code in the microcontroller that combines the received characters two-and-two into a binary value.
    Is the microcontroller application expected to compare an array with received data?
