Hi everyone there is a mistake when I want to write address 0x1d with the data 0x0f after called EZUSB_WriteI2C (); and EZUSB_ReadI2C (); the detail operations are as below:
BYTE xdata reg = 0x0f; BYTE xdata temp[32];
EZUSB_WriteI2C (0x1d, 0x01, ®); EZUSB_ReadI2C (0x1d, 0x01, &temp[0]);
after these code linked and download to board, the PC cant recognize the device, however these are commented out, the device can be normal recognized well
thx for your help
Call EZUSB_InitI2C() once, before calling these functions. It initializes I2C interrupt.
In an infinite loop, these I2C read/write functions poll the I2C status change caused by I2C interrupt. When no change occurs on the status, MCU execution is trapped in these functions.
Tsuneo
Hi Tsuneo Chinzei I did call EZUSB_InitI2C() to initialize the I2C bus. after that I called EZUSB_WriteI2C() and EZUSB_ReadI2C(). However you mentioned if the status of I2C is not change, and I call that two functions will cause the MCU pending, that is a good question, I will check it and thank you.
If you've installed the EZ-USB FX2LP dev kit CD, the source code for I2C utilities are placed in this folder, C:\Cypress\USB\Target\Lib\FX2\i2c.c and i2c_rw.c
CY3684 EZ-USB FX2LP Development Kit www.cypress.com/ Download SETUP_FX2LP_DVK_1004.exe on this page.
Add the source code to your project, and examine it on the debugger.
