I am using hypertrm for communicate with gsm modem,my problem is i am not using "local echo",but characters are displayed on hypertrm when i used key board storks,and it was not shows the responses from the modem, please tell me what is the problem?
1. which board / cpu / whatever are you developing code for? 2. use TeraTerm.
BR, /th.
hi dude ,i am using pic controller board and intel cpu,r u help me?
And why do you think a PIC microcontroller or an Intel PC-processor would matter?
Do you think the terminal program run on the PC would behave differently if you used an Atmel 8051 microcontroller, or if the PC had an AMD processor?
Local echo in a terminal program is obviously something that you control by looking through the options supported by the terminal program.
And the terminal program does not care what external hardware you have. A PIC controller. Another PC. A GSM modem. All the same to the terminal program.
I just wanted to know if this is something regarding to Keil tools :-)
Is Hyperterminal a Keil tool?
Do Keil make any tools for PC processors?
Do Keil make any tools for PIC processors?
What does ARM have to do with it?
It wasn't a comment to your comment, but a comment to the OP :)
Anyway, if the terminal program can't receive any characters, then the normal route to check is: - is there a MAX232 or similar level converter between the microcontroller and the RS232 serial port. - are all wires connected correctly, so rx/tx hasn't been switched, or the receiver and transmitter halves of the level converter switched. - let the microcontroller send out data, and verify that it sends anything. - verify that the bit lengths of the data sent by the microcontroller has the correct baudrate. - verify that this data reaches the PC (and with the correct signal levels) - verify that the PC terminal program has the correct communication settings (including turning off any hardware handshake, unless the port is expected to use hw handshake)
yes thanks i got the problem ,its nothing but wired problem
