hi guys...
i am trying to interface gsm modem and 8051, since iam very new to gsm modems iam not able to make it work...can any body help me in this regard, can any body give ur suggestions how to write the c code for the same??
I take it you are also very new to search functions.
Care to guess how often interfacing of 8051 processors with GSM modems is discussed on this forum?
How about taking a closer look at the search field in the uppper right of this web page...
If this doesn't give enough threads - how about trying Google?
hey dats not true i did try searching but din get c code to interface gsm modem and 8051.....am actually able to send sms and make call thru hyperterminal but not thru 8051...if u can help me in this regard i appreciate it.
No, you probably won't find ready-to-use 'C' code here - but you will find plenty of information that would allow you to write your own 'C' code.
There certainly is plenty of 'C' code for this on the wider internet - in addition to your usual search engine, try http://codesearch.google.com
Alternatively, if you are not interested in writing your own code, and want someone else to do it for you, see: http://www.keil.com/condb
