Are you using RTX? Can you help me?
I have a major problem with RTX and Keil don't seem to be able to help (as they want a simple scenario to cause the problem, but I cannot give them the hardware of course. Maybe I can make it go wrong using an evaluation board).
I'm using RTX as the backbone of a product that needs to run for extended periods of time without reboot (weeks...).
The problem is that RTX stops executing arbitrary tasks at arbitrary moments - they remain 'ready' but not get services. Today I discovered a task entering 'WAIT_MUT' while not using ANY mutex. My question: Are there any tips using RTX correctly? I am growing totally frustrated and tired of this, what am I supposed to tell the client?! I'm using latest and so expensive RL-ARM without any results whatsoever.
Can you share your experience with me?
Thanks you for your attention,
Tamir
  • How do you know that the task isn't using a mutex - possibly a mutex owned by the CRTL?
    What happens if you run older versions of RTX and compiler/CRTL?
  • Hello Per. This is the deal: No task ever locks more than one mutex at the time so there is no danger of a deadlock - all locks are very short and cannot hang. I have been having this problem for a very long time (months...) even before I started using any synchronization elements. Are you using RTX for a product that needs to run so long? I will have to check whether the task that I mentioned locks a mutex - I removed all of them from the program (except the ones in USB but that is not used at all when it goes wrong and there is no interaction between the tasks).
    Yesterday I managed to cause the system hang upon startup by replacing a 'os_evt_wait_and' with a polling loop (you see how desperate I am?). OK, I'm not giving up my time slice by why would that hang a system without any synchronization?!
    And how wonderful of the RTX kernel peripheral that it cannot tell you:
    1. what mutex is the system waiting for (anything will do!)
    2. the value of the PC per task.
    I'm telling you, if I cannot find the cause - RTX is going bye bye!
  • I'm currently developing a product based on the STR9, so the code is still in development.
    It is being built with version 3.50 - I have not yet upgraded to 3.70 because we have a problem with the Ethernet driver that Keil are investigating.
    The main point is, this product will be required to run 24/7 so it needs to be reliable. Whenever I have to move across to something else, I always try to leave the development board running the latest code.
    The longest period over which I have left it running is 27 days - No problems were encountered.
    On one occasion I did have something strange happen with a task misbehaving. It ended up being my fault. An incorrectly initialised pointer (in some test code) was causing RTX data to become corrupt.
  • I'm not at work right now, but quite sure that the RTX-based project is using 3.40. The devices must run 24x7 basically indefinitely. Because of the size of the test systems, I have a limited number of them available. The longest run (befire I have had to step software or do other work) is maybe three months. No device has during the past 18 months done a restart unless I have requested it, or the unit been power-cycled.
    A note here is that these units has LPC23xx processors (not Cortex-M3). The CRTL and RTX code is using the modes Keil compiled them in. All my own code is using the full ARM instruction set, and not the Thumb subset.
    Didn't you say earlier in some thread that your product has a Cortex-M3 processor? They must be quite a number of changes in the RTX code to adopt it for the interrupt-controller changes. A change between Thumb and Thumb2 could potentially also change the instruction mix even for identical code.
  • Per,
    Thanks for your reply. We are using a LPC2478. It is absolutely frustrating, but I must accept that I am doing something wrong or maybe it is a hardware issue (memory, timing...). I will strip a controller of just about the most elementary stuff to try to pin-point the problem...
  • Tamir,
    That was what I had to do to find the mutex deadlock between the ARM libraries and the FlashFS. Its even harder to find if it is infrequent deadlock.
    Its very frustrating when the OS and its libraries cause a deadlock! Definitely not what you expect of a real-time OS.
  • Just as Stuart Wright notes, I was wondering if your thread could have got stuck on a mutex inside the ARM library even if your own code doesn't make use of any mutex.
    How critical is a reboot?
    Do you have any inter-process supervision, that could watchdog-reset your board if any thread gets stuck?
    You you have long boot times, or lose important synchronization information that takes time (or is is impossible) to recollect?
    I would recommend that you have a quite aggresive watchdog timeout, and and design all threads so that they they gets regularly woken up even if you have no work for them. Whenever they wake up, they should then sign off that they are alive. At the same time, they should compute how long time it was since the last time they got useful work todo, and decide if they are unhappy either with a thread they expect data from, or with a thread that was expected to eat produced data.
    In the end, the watchdog shouldn't be kicked unless all threads and (when applicable) interrupt handlers are alive and working.
    Having extra dummy events in the system may possibly increase the processor load with 1%, but it is often very critical to notice and react when the application is only partially working.
  • Per,
    I have implemented most of your recommendations already. I have been able to induce a failure much faster by bombing the controller with UART trash, and it seems as if the responsible is a chunk of code I added yesterday (at least, this failure scenario is solved, I hope, but it does not explain the failures before I wrote it!). Franc Urbank (the RTX guru) is trying to help, too. I will keep you informed as we'll know more after the weekend.
  • Tamir,
    your problem sounds really serious.
    Crossing all available fingers you'll catch it.
    I am quite new to ARM & Keil, but been in the embedded business for quite a while.
    My impression is that this RTX in general lacks all things giving "comfort" of debug aid.
    Other OS offer a lot more compared to Keil, eg Segger's embOS.
    One of the first things for me to do was to write sort of a schedule monitor to see what task was consuming what time. I found that the basic basics where there (the rt_agent_xx stuff)
    But it was basic and over all nonfunctional. So quite a bit left to code. Then I got me a help to capture all exception-relevant data .. and so on
    All that - in my opinion - stuff that should have been in the box - at least at that price.
    What I'd do:
    a) Is there a chance the the mutexes might get modified accidentally by sick pointers? What's your application (and your coding style ) alike ? On "good" days I manage really weird things ;)))
    Do you have the change to compile on a different machine (eg Visual Studio at highest warn levels) to get rid off the chance of such a problem ?
    b) simply modify the OS
    If you think it is a proper call that changes the mutex, why simply not track all mutex accesses ?
    (for a reduced time of course)
    If you don't have so many accesses , maybe yu can put them all into RAM , let the machine run a while and dump them after next reset (but beware to put them in non cleared area.
    Hope these idease were of any help
    G O O D L U C K !!
    Uli
  • just to go in detail with b)
    if you can simply get the mutex to change to a wrong value (as you mentioned above), try to track all intended mutex changes with their corresponding task ids.
    Maybe you can then detect, that there is no "set_wrong" at all or you can detect the failing task.
    even more luck ;)
    ULI
  • Uli,
    Thanks for your reply. I made it home in a collapsed state :-)
    Here is the deal: the system kept on crashing even after removing all mutexes. I did find 2 problems due:
    1. There was a path in the program that attempted to lock a mutex while at interrupt context. a little assembly magic solved that.
    2. there was a problem in the communication task that could have locked the direction of the RS-485. I don't fully understand why, but the code is now more solid.
    The controllers are now running on my desk. If they don't hang by Monday, I think I can consider the situation as an improvement, even though the system used to crash before I started using mutexes etc and ran for over a week before without a problem (only lately it became so unstable). I will post what happened.
  • what I really miss in uv3/4/RTX combination:
    * LR per task
    * locked system resources per task
    * more aid to debug
    but the greatest benefit would probably be something my processor (LPC2478) does not have: a MMU...
  • Here is an idea to improve RTX:
    Offer a debug mode binary / compile time macro that causes the system to guard critical data with a checksum that is being re-calculated every time the kernel is active. when a program overwrites something thus altering the checksum, the processor calls a callback and hangs, providing the history of the last 100 milliseconds of operation in terms of tasks that ran and interrupts that occurred.
  • Something else that can help a lot is the kernel causing the processor to immediately go to abort mode, if an attempt is made to use anything that must not be used in any exception mode from anything but user mode.
  • Tamir,
    Just out of interest, have you found the problem?
    I see in:
    http://www.keil.com/forum/docs/thread15089.asp
    you talk about a wild pointer.
    Was it that?
