Hi everybody!
I'm trying to get the AGDI example (SampTarg) from the Keil site to work but when I do as the application note 145 says I get the following problem:
When launching uvision I get the message that no debug information is available in the binaries for Uv3.exe and wen i want to select the created DLL in the debug menu of the keil project it is not in the list. I tried it with another DLL and it worked, so the path is right (in the Tools.ini).
I'm using uvision3 and visual studio 2008.
Guess it is maybe a wrong setting in the linking/debugging options in Visual Studio... but maybe someone else can help me with this problem :-)
Many thx in advance!
your Martin
