Error: L6200E: Symbol multiply defined compiling Adam Dunkels uIP
I get this error when compiling Adam Dunkels uIP adapted to LPC-2124 board. fs.c contains the functions to open files (fs_open) and fsdata.c contains the html code of these files. I'm completely stuck with this, I would apreciate any help.
Thanks.
error log:
uIP-2124.axf: Error: L6200E: Symbol file_cgi_files multiply defined (by fsdata.o and fs.o).
uIP-2124.axf: Error: L6200E: Symbol file_cgi_stats multiply defined (by fsdata.o and fs.o).
uIP-2124.axf: Error: L6200E: Symbol file_cgi_tcp multiply defined (by fsdata.o and fs.o).
uIP-2124.axf: Error: L6200E: Symbol file_img_bg_png multiply defined (by fsdata.o and fs.o).
uIP-2124.axf: Error: L6200E: Symbol file_about_html multiply defined (by fsdata.o and fs.o).
uIP-2124.axf: Error: L6200E: Symbol file_control_html multiply defined (by fsdata.o and fs.o).
uIP-2124.axf: Error: L6200E: Symbol file_404_html multiply defined (by fsdata.o and fs.o).
uIP-2124.axf: Error: L6200E: Symbol file_files_footer_plain multiply defined (by fsdata.o and fs.o).
uIP-2124.axf: Error: L6200E: Symbol file_files_header_html multiply defined (by fsdata.o and fs.o).
uIP-2124.axf: Error: L6200E: Symbol file_index_html multiply defined (by fsdata.o and fs.o).
uIP-2124.axf: Error: L6200E: Symbol file_stats_footer_plain multiply defined (by fsdata.o and fs.o).
uIP-2124.axf: Error: L6200E: Symbol file_stats_header_html multiply defined (by fsdata.o and fs.o).
uIP-2124.axf: Error: L6200E: Symbol file_tcp_footer_plain multiply defined (by fsdata.o and fs.o).
uIP-2124.axf: Error: L6200E: Symbol file_tcp_header_html multiply defined (by fsdata.o and fs.o).
  • Look at the error messages, read them carefully, and think what they are telling you!
    eg,
    That's telling you that both fsdata.o and fs.o contain a definition of file_cgi_files
    Now, fsdata.o and fs.o are the Object files produced by compiling fsdata.c and fs.c respectively.
    Therefore, look at the source code in fsdata.c and fs.c to see if they do, in fact, both contain a definition of file_cgi_files - then decide which one to keep, and which to remove.
