Hi, is there someone having a driver for the Teridian 78Q2133 ethernet PHY? I adapted the example out of the AT91SAM9260 software package from Atmel to wotk with this PHY, but the auto negotiation always fails, resulting in a time out.
Thanks for your help.
I don't know much about this; but Linux supports this device.
lwn.net/.../
diff --git a/drivers/net/arm/at91_ether.h b/drivers/net/arm/at91_ether.h index b6b665d..a38fd2d 100644 --- a/drivers/net/arm/at91_ether.h +++ b/drivers/net/arm/at91_ether.h @@ -17,39 +17,46 @@ /* Davicom 9161 PHY */ -#define MII_DM9161_ID 0x0181b880 -#define MII_DM9161A_ID 0x0181b8a0 - -/* Davicom specific registers */ -#define MII_DSCR_REG 16 -#define MII_DSCSR_REG 17 -#define MII_DSINTR_REG 21 +#define MII_DM9161_ID 0x0181b880 +#define MII_DM9161A_ID 0x0181b8a0 +#define MII_DSCR_REG 16 +#define MII_DSCSR_REG 17 +#define MII_DSINTR_REG 21 /* Intel LXT971A PHY */ -#define MII_LXT971A_ID 0x001378E0 - -/* Intel specific registers */ -#define MII_ISINTE_REG 18 -#define MII_ISINTS_REG 19 -#define MII_LEDCTRL_REG 20 +#define MII_LXT971A_ID 0x001378E0 +#define MII_ISINTE_REG 18 +#define MII_ISINTS_REG 19 +#define MII_LEDCTRL_REG 20 /* Realtek RTL8201 PHY */ -#define MII_RTL8201_ID 0x00008200 +#define MII_RTL8201_ID 0x00008200 /* Broadcom BCM5221 PHY */ -#define MII_BCM5221_ID 0x004061e0 - -/* Broadcom specific registers */ -#define MII_BCMINTR_REG 26 +#define MII_BCM5221_ID 0x004061e0 +#define MII_BCMINTR_REG 26 /* National Semiconductor DP83847 */ -#define MII_DP83847_ID 0x20005c30 +#define MII_DP83847_ID 0x20005c30 + +/* National Semiconductor DP83848 */ +#define MII_DP83848_ID 0x20005c90 +#define MII_DPPHYSTS_REG 16 +#define MII_DPMICR_REG 17 +#define MII_DPMISR_REG 18 /* Altima AC101L PHY */ -#define MII_AC101L_ID 0x00225520 +#define MII_AC101L_ID 0x00225520 /* Micrel KS8721 PHY */ -#define MII_KS8721_ID 0x00221610 +#define MII_KS8721_ID 0x00221610 + +/* Teridian 78Q2123/78Q2133 */ +#define MII_T78Q21x3_ID 0x000e7230 +#define MII_T78Q21INT_REG 17
License might be an issue.
I already had a look at this. The main problem is, that the auto negotiation bit in the status register is not beeing set. I only see the link status and remote fault bit changing. Same in the interrupt status reg: link partner ack and link status change, but uto negotiation complete flag does not.
I almost don't know anything about Networking.
But I know that Autonegotiation is the behavior between two devices. Maybe the problem is not on the Teridian 78Q2133? Did you check the device at another side?
Incompatible? en.wikipedia.org/.../Autonegotiation
The first version of the autonegotiation specification, IEEE 802.3u, was open to different interpretations. Although most manufacturers implemented this standard in one way, some others, including network giant Cisco, implemented it in a different way. Autonegotiation between devices that implemented it differently failed. This led many network administrators to not depend on autonegotiation and instead manually set the speed and duplex mode of each network interface card. Even Cisco recommended its customers not to use autonegotiation.
When using WinCE which is available for this board, the ethernet connection works fine. Thus it must be a configuration fault...
