Hello people!
First time writing here.. hope will find some help ;)
Before using ARM architecture I used XC167 processor. Now I had some problems with implementing on ARM architerure (mdk arm) some functionality supported in C166 keil. Maybe somebody can help me with this:
1. In C166 was #pragma ORDER which allow you to keep all variables and functions in the same order like in C source. Is it possible to do it in keil arm compiler?
2. In C166 was very very usefull for me function like "srom.h".
Excatly what I need is something like this: http://www.keil.com/appnotes/files/apnt_138.pdf
Regarding to this PDF I need functionality like this " LINKER EXTENSIONS Extensions in the L166 Linker/Locator allow you to: " Execute code and access constants at different RAM addresses than what is actually stored in ROM. " Access the section starting address and section length directly from the C language. These extensions let you relocate your FLASH Erase and FLASH Write routines to RAM before execution. You no longer have to write a separate program for the In-System FLASH programming software. Additionally, no code overhead is introduced since function pointers are not required to call routines that modify the FLASH.
COMPILER EXTENSIONS A new header file (SROM.H) is included in the INC directory. This file contains macros that provide you with the ROM address," (end)
Do somebody know something how to make something like this using Keil for ARM???
All suggestions very apprecieated
1. See infocenter.arm.com/.../armccref_chdbjdbi.htm
Also, using structures prevents data reordering.
2. Check the MCU header files provided by MDK for according #define's. Otherwise you can access "linker defined symbols" to get the information you need.
infocenter.arm.com/.../armlink_chdcgbjd.htm
Regards Marcus http://www.doulos.com/arm/
ARM's stated reason for acquiring Keil was to ease the migration from 8 & 16 bit architectures.
So, surely, it would be in their interests to promote this aim by providing "migration guides" that tell you how to do the things you're familiar with in the new, ARM tools...
or to point out where they're no longer necessary!
