Hi All,
I have a Keil RealView MDK v3.15b.exe File.
When i am trying to install this file I am getting
Following message
"Checksum Error The Installation file is corrupted and installation must be terminated "
How to solve this issue..?
With regards, Murthy.R
As far as you can read your installation file is corrupted Try to download the file again and have a new try.
Another, more remote possibility would be that the computers memory is defective. If the problem persists even after downloading the file again, run some memory tests.
If you can't get a good download, and you're sure it's not a fault in your PC hardware, you can request a CD:
www.keil.com/.../cdrom.asp
thanks to all. i have tried with some other version of the exe file.the same result i got. so that i requested a CD.
Thanks & Regards, Murthy.R
