hi all i am new to arm so i hav eno much idea about thing kindly help with the query.I am trying to interface an 16x2 lcd display on to my mcb2140 board with lpc2148.I have got some code with me but it does not display anything i want to know how to test tat the display is working fine before i go ahead with the code alteration
thanks in advance
hi, you can check enable,register select,rd/wr pins going high low according to your program if you have simulator then you can check on that also make sure that pins are open drain and with pull of 10Kohm bye take care
thanks buddy..cld u please tell wat should be the power supply given in order for the lcd to work..i am using 3.3v, is this sufficient
We don't even know that display you are using, so what do you expect from us?
What does the datasheet for the display say about supply voltages?
hi, for microcontroller it is 3.3V but for Lcd it is 5V if you have debugger then putting breakpoint also you can trace your code bye take care
How do you know that?
simple: he does not. he also made a couple of other, fantastic and baseless claims in his previous post. should we nick name him "bbbppppp" "bbbpppppp" from this moment on :-) ???
Where is "professor" juisti when you need him?!?! you know, the guy that says "juisti is there to help you rather then to tell your Please read the manual".
<quote> Where is "professor" juisti when you need him?!?! you know, the guy that says "juisti is there to help you rather then to tell your Please read the manual". </quote>
I am here watching all youre feeble answers.
but why answer when I donut know the anser??
Zeuisti.
Always your friend.
here is another feeble (now word there, "professor") statement: I wish you applied this approach more often!
I meant: "nice word there, "profess..."
Tamir,
Why do you alweys pull people into the talk?
Plz, you do not be feebel.
Zeusti,
ok.
