hello, I use a c163 and I try to create a simple PWM signal, so i've created a structure with the members i need(positive duty ,negative duty and period) everything works perfect when i run from ram memory but when i run from flash memory is not working.
Could anyone help me because i can't figure out what's the problem? thank you
