Hii...
I wanted to know to use the incircuit emulator for TI's cc2430 board...i have the JTAG for debug provided by TI..can I make use of that and debug?Actually I've using Tinyos and written applications in nesC,There is no target for CC2430DK..I have used the respective Cprogram... but I'm not able to find out how to use the incircuit debugging...Kindly help me as to how to do and kindly let me know if there are good manuals regarding this...
With warm regards.. Swaroopa.
If it's provided by TI, then you should consult TI for support...
Hi..
The development is provided by Ti which comes with IAR workbench..but I wanted to know if Keil has support for CC2430 and how it can be done,because I couldn't find much documentation regarding this..
Thanks in advance.. Swaroopa
It is highly unlikely that you'll get a debugger for IAR to work with Keil - or vice-versa.
Since TI are so firmly comitted to IAR, is there any particular reason for you not to use IAR?
"I wanted to know if Keil has support for CC2430"
Keil detail all their supported chips here:
http://www.keil.com/dd
