What is the difference between the s series vs the c series?
is it true that they have got the m series to?
Are we talking about cars?
Or where you thinking about AT89S51/AT89C51 from Atmel? Or something else?
If Atmel chips, then an important difference is that one of the chips is old and Atmel don't like to sell it ;)
Always spend a bit of time on your questions. Read the question and think about the amount of information supplied. Will it be enough for other people to understand your question?
You didn't even select a toolset, so we don't know if you have found any ARM chips that exists in C and S models...
C series need high voltage parallel programming to burn in the hex code...not recommend...better go for the S series that support ISP...
M series are the bad color and you must not use !(-o-)!
Sounds like it. Mercedes, possibly. Though they call 'em "class", not "series".
C series need ....
www.999inks.co.uk/.../
These look quite nice: www2.kef.com/.../c-series
Or maybe these: www.btoffice.com/.../c-series.html
Or these: www.trumauk.com/.../
