problems with the startup file
I'm using this startup file for the AT91SAM9263 controller.
The main function will be executed - but the programm will only work for approximately a minute (led blinky and trasmitting information by the debug rs232 interface). After that minute everything stops working (at the same time).
Maybe a problem with the heap or stack management, configurated in the startup file?
The starting point in the startup file is (--entry resetHandler) - misc options:
;     KEIL startup file for AT91SAM9263 .
ARM_MODE_USR        EQU     0x10
ARM_MODE_FIQ        EQU     0x11
ARM_MODE_IRQ        EQU     0x12
ARM_MODE_SVC        EQU     0x13
ARM_MODE_ABT        EQU     0x17
ARM_MODE_UND        EQU     0x1B
ARM_MODE_SYS        EQU     0x1F
I_BIT               EQU     0x80            ; when I bit is set, IRQ is disabled
F_BIT               EQU     0x40            ; when F bit is set, FIQ is disabled
AT91C_BASE_AIC      EQU     0xFFFFF000
AIC_IVR             EQU     0x100
AIC_EOICR           EQU     0x130
UND_Stack_Size      EQU     0x00000000
SVC_Stack_Size      EQU     0x00000100
ABT_Stack_Size      EQU     0x00000000
FIQ_Stack_Size      EQU     0x00000000
IRQ_Stack_Size      EQU     0x00000080
USR_Stack_Size      EQU     0x00000400
        PRESERVE8
; Area Definition and Entry Point
; Startup Code must be linked first at Address at which it expects to run.
        AREA    VECTOR, CODE
        ARM
; Exception Vectors
Vectors
                                LDR     pc,=resetHandler
undefVector
                            b           undefVector             ; Undefined instruction
swiVector
                        b       swiVector               ; Software interrupt
prefetchAbortVector
                        b       prefetchAbortVector     ; Prefetch abort
dataAbortVector
                        b       dataAbortVector         ; Data abort
reservedVector
                        b       reservedVector          ; Reserved for future use
irqVector
        b       irqHandler              ; Interrupt
fiqVector
                                        ; Fast interrupt
; Handles a fast interrupt request by branching to the address defined in the
; AIC.
fiqHandler
        b       fiqHandler
; Handles incoming interrupt requests by branching to the corresponding
; handler, as defined in the AIC. Supports interrupt nesting.
irqHandler
        ;  Save interrupt context on the stack to allow nesting */
        SUB     lr, lr, #4
        STMFD   sp!, {lr}
        MRS     lr, SPSR
        STMFD   sp!, {r0,r1,lr}
        ; Write in the IVR to support Protect Mode */
        LDR     lr, =AT91C_BASE_AIC
        LDR     r0, [r14, #AIC_IVR]
        STR     lr, [r14, #AIC_IVR]
        ; Branch to interrupt handler in Supervisor mode */
        MSR     CPSR_c, #ARM_MODE_SVC
        STMFD   sp!, {r1-r4, r12, lr}
        MOV     lr, pc
        BX      r0
        LDMIA   sp!, {r1-r4, r12, lr}
        MSR     CPSR_c, #ARM_MODE_IRQ | I_BIT
        ; Acknowledge interrupt */
        STR     lr, [r14, #AIC_EOICR]
        ; Restore interrupt context and branch back to calling code
        LDMIA   sp!, {r0,r1,lr}
        MSR     SPSR_cxsf, lr
        LDMIA   sp!, {pc}^
; After a reset, execution starts here,
                AREA  cstartup, CODE
                ENTRY        ; Entry point for the application
; Reset Handler
        EXPORT  resetHandler
        IMPORT  |Image$$Fixed_region$$Limit|
        IMPORT  |Image$$Relocate_region$$Base|
        IMPORT  |Image$$Relocate_region$$ZI$$Base|
        IMPORT  |Image$$Relocate_region$$ZI$$Limit|
        IMPORT  |Image$$ARM_LIB_STACK$$Base|
        IMPORT  |Image$$ARM_LIB_STACK$$ZI$$Limit|
                ; Perform low-level initialization of the chip using LowLevelInit()
                IMPORT  LowLevelInit
resetHandler
        ; Set pc to actual code location (i.e. not in remap zone)
            LDR     pc, =label
label
                ; Set up temporary stack (Top of the SRAM)
                LDR     r0, = |Image$$ARM_LIB_STACK$$ZI$$Limit|
        MOV     sp, r0
                ; Call Low level init
            LDR     r0, =LowLevelInit
        MOV     lr, pc
        BX      r0
;Initialize the Relocate_region segment
                LDR     r0, = |Image$$Fixed_region$$Limit|
                LDR     r1, = |Image$$Relocate_region$$Base|
                LDR     r3, = |Image$$Relocate_region$$ZI$$Base|
            CMP     r0, r1
        BEQ     %1
        ; Copy init data
0       CMP     r1, r3
        LDRCC   r2, [r0], #4
        STRCC   r2, [r1], #4
        BCC     %0
1       LDR     r1, =|Image$$Relocate_region$$ZI$$Limit|
        MOV     r2, #0
2       CMP     r3, r1
        STRCC   r2, [r3], #4
        BCC     %2
; Setup Stack for each mode
        LDR     R0, = |Image$$ARM_LIB_STACK$$ZI$$Limit|
;  Enter Undefined Instruction Mode and set its Stack Pointer
                MSR     CPSR_c, #ARM_MODE_UND:OR:I_BIT:OR:F_BIT
                MOV     SP, R0
                SUB     R0, R0, #UND_Stack_Size
;  Enter Abort Mode and set its Stack Pointer
                MSR     CPSR_c, #ARM_MODE_ABT:OR:I_BIT:OR:F_BIT
                MOV     SP, R0
                SUB     R0, R0, #ABT_Stack_Size
;  Enter FIQ Mode and set its Stack Pointer
                MSR     CPSR_c, #ARM_MODE_FIQ:OR:I_BIT:OR:F_BIT
                MOV     SP, R0
                SUB     R0, R0, #FIQ_Stack_Size
;  Enter IRQ Mode and set its Stack Pointer
        MSR     CPSR_c, #ARM_MODE_IRQ:OR:I_BIT:OR:F_BIT
        MOV     SP, R0
;        SUB     R4, SP, #IRQ_Stack_Size
        SUB     R0, SP, #IRQ_Stack_Size
; Supervisor mode (interrupts enabled)
        MSR     CPSR_c, #ARM_MODE_SVC:OR:I_BIT:OR:F_BIT
;        MOV     SP, R4
                MOV     SP, R0
;        SUB     R4, SP, #SVC_Stack_Size
        SUB     R0, SP, #SVC_Stack_Size
;  Enter User Mode and set its Stack Pointer
        MSR     CPSR_c, #ARM_MODE_USR
        MOV     SP, R0
        SUB     SL, SP, #USR_Stack_Size
; Enter the C code
        IMPORT  __main
        LDR     R0, =__main
        BX      R0
        END
best regards
Scott
