rebuild got warnings
I use Keil uVision to bulid a target there is no errors and warings.But Rebulid got 4 warinings,like:
Warning C280: "ad_ ptr" unreferenced local variable
  • 'Build' processes only those files that hav changed;
    'Rebuild' processes all files.
    So, presumably, the errors where in files that were not processed by the 'Build'...
  • Oh, thanks. But how to deal with the warnings, like <unreferenced local varible"size"> What does it mean?
  • "... <unreferenced local varible"size"> What does it mean?"
    That you are nor referencing local variable "size".
    "... But how to deal with the warnings, ..."
    Reference "size".
  • #include <Nordic\reg24lu1.h>
    #include "hal_nrf.h"
    #include "cklf.h"
    #include "cpu.h"
    #include "hal_usb.h"
    #include "hal_usb_hid.h"
    #include "usb_api.h"
    #include "nordic_common.h"
    static hal_usb_dev_req_resp_t device_req_cb(hal_usb_device_req* req, uint8_t** data_ptr, uint16_t* size) reentrant;
    static void suspend_cb(uint8_t allow_remote_wu) reentrant;
    static void resume_cb() reentrant;
    static void reset_cb() reentrant;
    static uint8_t ep_1_in_cb(uint8_t *adr_ptr, uint8_t* size) reentrant;
    static uint8_t ep_2_in_cb(uint8_t *adr_ptr, uint8_t* size) reentrant;
    bool ep1_sent, ep2_sent;
    volatile usb_state_t usb_state;
    void usb_init(void)
      hal_usb_init(true, device_req_cb, reset_cb, resume_cb, suspend_cb);
      hal_usb_endpoint_config(0x81, 32, ep_1_in_cb);
      hal_usb_endpoint_config(0x82, 32, ep_2_in_cb);
      ep1_sent = true;
      ep2_sent = true;
      usb_state = USB_AWAKE;
    void usb_wakeup(void)
      hal_usb_wakeup();
    usb_state_t usb_get_state()
      return usb_state;
    void usb_wait_for_configuration(void)
      volatile hal_usb_state_t usb_hal_state;
      do
        usb_hal_state = hal_usb_get_state();
      while(usb_hal_state != CONFIGURED);
    void usb_send_packet(uint8_t* in_data, uint8_t ep_num, uint8_t size)
      if(ep_num == USB_EP_MOUSE)
        while(!ep1_sent)
        ep1_sent = false;
      else
      if(ep_num == USB_EP_KEYBOARD)
        while(!ep2_sent)
        ep2_sent = false;
      hal_usb_send_data(0x80 | ep_num, in_data, size);
        hal_usb_dev_req_resp_t retval;
        if( hal_usb_hid_device_req_proc(req, data_ptr, size, &retval) == true )
            // The request was processed with the result stored in the retval variable
            return retval;
        else
            // The request was *not* processed by the HID subsystem
            return STALL;
        return STALL;
      USBSLP = 1; // Disable USB clock (auto clear)
      if (allow_remote_wu == 1)
        // Enable wake-up on USB and USBWU (bit3:0=1010)
        // Enable MCU_WU (bit5:4=10 ) on RTC
        WUCONF = (BIT_5 | BIT_3 | BIT_1);
        usb_state = USB_REM_WU_ENABLE;
      else
        WUCONF = (BIT_3 | BIT_1);
        usb_state = USB_REM_WU_DISABLE;
      ep1_sent = true;
      ep2_sent = true;
      ep1_sent = true;
      ep2_sent = true;
      ep1_sent = true;
      return 0x60; // NAK
      ep2_sent = true;
      return 0x60; // NAK
    warning C280:'adr_ptr':unreferenced local variable
    warning C280:'size': unreferenced local variable
  • Yes. Unused variables are unreferenced. So you get a warning. So your choices are:
    1) Make use of them.
    2) Remove them (if global or local)
    3) Remove name of unused function parameter,keeping just the type as place holder - or adjust the function to take fewer parameters.
  • "So your choices are:"
    Or, like I said,
    4) Reference them. For example, the following works for many compilers.
        (void)adr_ptr; (void)size;          /* Reference unused parms */
        ep1_sent = true;
        return 0x60; // NAK
  • I included your alternative in my "use them".
    But the important thing is that this is not Keil-specific. It is the same for just about all C/C++ compilers.
  • That's not quite the same as just referencing them.
    "Use them" implies putting them to some functional use - whereas Dan's suggestion just references them without actually doing anything with them at all.
    And there's the problem: some compilers will give a warning along the lines of "code has no effect" for such references...
    BTW: Is it just me, or does the ARM compiler not warn about unused parameters?
  • It (4) works for many compilers but for C251 it just yields another warning.
    The alternative (3) to just mention the type without a name also just yields another warning.
    Whatever steps you try to avoid, finally you will have to #pragma warning disable _some_ warning, which looks very ugly in the code to do it locally.
  • Keil also has
    __attribute__((unused)) variable
